Does not turn on the back of Ford Fiesta 1.6 16v 90cv
14 years 4 months before #24732 by manual-mecanica
Hi, I need help with the reverse light. I've checked everything except the reverse sensor, which I don't know where it is. If anyone can lend me a hand, I would be very grateful. Thank you. :)
14 years 4 months before #24760 by manual-mecanica
Manual-mechanics' response on the topic Re: Ford Fiesta 1.6 16v 90hp reverse gear won't start
It has to be mounted on the gearbox, dry from the tail
14 years 4 months before #24762 by manual-mecanica
The same thing happened to me. I went crazy trying to find the problem, and it was the reverse gear sensor on the gearbox. If you get under the car, you'll find it on the left. It's a connector with two wires coming out of it. It's easy to locate.
