MY HONDA DAMPER screw problem
13 years 11 months before #24640 by manual-mecanica
MY Honda Damper screw problem published by Manual-Mecanica
Friends I hope you help me I have a problem with my Honda Civic 99 engine 1.6 16 valves! The damage it has is that I got the Damper screw with the crankshaft, it is not so much that if it is not the 2 time it happens to me and every time the Damper and crankshaft for another for the other the amount and the 2 months more or less part! Who can help me with respect to this ... I mean that it doesn't look good, oq! I have the workshop manual and I do the manual! I no longer see what to do here where I live and there are several that tell me that it is bad of those deep that I do not think it is like that !!
I thank you if they help me
13 years 11 months before #24642 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with the Damper screw of my Honda
Hello, how are you ... it is a lie that these engines suffer from that problem. In general, when it occurs, it is due to a bad operation of the technician, in order to give you a help I understand that the engine has not intervened, I mean not to be rectified its bench circle, if the ropTura is presented in the outside where the Damper is mounted, it must be checked that the damper protrudes from the tip of the crankshaft and that the screw tightens on the damper In false this screws carries 134lb-ft applied fat in the thread and especially between the head of the screw and the arendla Check in a rectifier and look that this does not turn outside its own axis, that it is not crooked even though some of these crankshafts have not been beaten and tend to twist what is overwhelmed to break, quant me more about this problem, I think you can be able to hire you ,,
13 years 11 months before #24643 by manual-mecanica
I forgot ... If it leaves at the tip of the crankshaft to send it to fix a welding filling and polishing is not a good idea that does not work will always break again by the thermal process to which it is subjected and the work is arduous so it does not endure is better one used but reviewed in a rectifier.
13 years 11 months before #24659 by manual-mecanica
Thanks Daninovato ... if the engine is never rectified in anything ... and if the tip of the crankshaft! The 1st time it was what "call the wedge" and the damper ate the second I imaguino that it was only the wedge through the tip I was intact but the Damper awarded inside and I remain half screw on the internal part of the crankshaft ... coincidentally he uncovers it to empy everything for a oil boat, the block does not notice wear but if I see a small game between the pistons and the little game between the pistons and But minimal tells me that it is fine ...! I think I'm going to buy the rings just! is that game normal? The car has 3 months without using osa q nio I turn to it!
13 years 11 months before #24667 by manual-mecanica
Czech that the wedge is well adjusted, because otherwise the problem should also walk and check the degree of hardness of the screw, because it can be too hard for the application (this in the second time I started).
