Help Jetta 2002
14 years 3 months before #24329 by manual-mecanica
Help Jetta 2002 posted by Manual-Mecanica
Hi, I need help with a Jetta 2002 motor 2.0 since it does not turn on and has no fault code.
He already revives fuel pump and works more there is no voltage in the spark plugs but the module of spark plugs and if it reaches a voltage. The spark plug module connector is 6 pins.
Thank you........
14 years 3 months before #24344 by manual-mecanica
Manual-Mecanica Answer on the Re: Help Jetta 2002
The Volkswagen has a distributor with an album inside that acts as a magnet captor to take the spark step, if the coil works correctly then it is an accounting album problem. Obio that you first see the distributor cover.
14 years 3 months before #24353 by manual-mecanica
Most likely it is your coil, but also check the crankshaft sensor, Czech in the harness that you not only have current and earth, but also an intermittent signal signal of crankshaft
