WOLSVAGEN PASSAT OIL PRESSURE 1.8T 2004 20VAL.
12 years 8 months before #40511 by manual-mecanica
Manual-Mecanica Response on the Re: pressure Wolsvagen Passat 1.8T 2004 20val.
Tell me exactly that symptoms and what motor your car has
12 years 8 months before #40527 by manual-mecanica
Hello good afternoon, look is a passat 1.8 turbo 20 valves this new 107 6552 send me a msj and I return the call to you
12 years 8 months before #40538 by manual-mecanica
As you tell me, the problem could be your oil pump again, you put the original?, I have had several Passat Audi 1.8 turbo that the witness of low oil pressure is turned on, and changing the pump I have solved the problem, as the original is something expensive, my refacionist has been aware in Bruck brand and I have not had any problem, if you washed well, you have any moving noise. Changed the oil pressure hose that reaches the turbo, since it is very common that this hose is also covered and the turbo ends up, any problem you can mark my cell is 5518 447144, I am in the DF
