Motor problems
14 years 2 weeks before #24082 by manual-mecanica
Motor problems published by Manual-Mecanica
I have problems with the water pressure, when the engine lifts a temperature of 90 ° the pressure of oil low almost zero when I walk it and when I walk to CNG it is maintained at 15 °, I would like to know if changing the bearings would be able to press again in the motor
14 years 2 weeks before #24090 by manual-mecanica
Manual-Mecanica Response on the Re: Motor Problems
Hello Goju.
That fault is characteristic of spent bench caps, of course you should also check those of connecting rods and the pump. Luck.
Miguel
