Temperature problem
13 years 11 months before #23992 by manual-mecanica
Temperature problem posted by manual-mecanica
Greetings ......
I have a 2006 corsa that rehearses even having the 02 burning electrors.
I have placed the electro fans to work at fast speed directly with a suiche. And when I am a long time in a tail at noon the car is overheats.
It also eliminates thermostat and continuous problem.
What can be happening ??????
13 years 11 months before #23994 by manual-mecanica
Manual-Mecanica Response on the Re: Temperature problem
It may be that the water pump has broken and the water is not circulating. greetings
13 years 11 months before #23996 by manual-mecanica
Verify the refrigeration circuit that is working normal (thermostat, water pump, bulb, radiator, etc.) otherwise you will have to see butt joint. Advice that place everything as a factory ex: thermostat.
13 years 11 months before #23998 by manual-mecanica
Hi Lorenzo73.
Verify if the band is not sliding on the pump pulley, if that is fine, then disassemble the pump and review it, it is possible that the impeller is deteriorated and do not leave it without the thermostat. Luck.
Miguel
13 years 11 months before #23999 by manual-mecanica
In addition to what the companions told you, it is very important to check the water recipient container lid, it may be damaged and check that the water level is not lowering when this ignition collides some 10psi of pressure to the refre system and check that there are no leaks ...
On the other hand I need the manual of Kia Cedona if they can help me I thank you for anything I can help you this is my cell phone.
