Battery download
13 years 11 months before #23932 by manual-mecanica
Battery download published by Manual-Mecanica
I had a short with the windshield wiper and now the battery is discharged despite the fact that the windshield wiper engine is disconnected and they go twice that I recharge the battery and devastate anyway, my truck is a Town and Country 96. You can help me. thank you
13 years 11 months before #23934 by manual-mecanica
Manual-Mecanica Answer on the Re: battery download
There must be a short one on some other side! The best way to check it is to measure the current with the car off, not the voltage but the current is to say the amps, for that you must connect in series only a terminal of the battery and see when it marks you, a normal value is approx about 0.2 amps if you have much more of that is that there you have some short!
13 years 11 months before #23936 by manual-mecanica
Sometimes TMBN passes that a poorly installed radio makes a consumption that is not seen, the test of the tester, which is connected in series between the battery terminal
13 years 11 months before #23937 by manual-mecanica
13 years 11 months before #23947 by manual-mecanica
The fuse that works with the windshield wiper may be connected to the load and that is why the battery does not charge you
