tachometer
14 years 3 months before #23907 by manual-mecanica
TACOMETRO PUBLISHED BY MANUAL-MECANICA
As I do to install a revolution tacometer in my fiat siena ful Fulion Motor 1300 Year 1999 This brings independent bovine for every 2 cylinders and I don't know where to take Als Coneciones I thank who can help me, I am from Venezuela
14 years 3 months before #23908 by manual-mecanica
Manual-Mecanica Answer on the Re: Tacometer
I have no experience in that brand because here it almost does not come but if you have the diagrams in it you should indicate which is the output of tacomethre, even the ignition modules bring out (tach) that is of tacometer. All ECUs bring tacomethar outlet because it is an instrument panel accessory.
14 years 3 months before #23946 by manual-mecanica
Or if you don't connect it from the alternator
