Citroen C3 starter engine
14 years 1 month before #23584 by manual-mecanica
Citroen C3 start motor posted by Manual-Mecanica
Could you tell me where
the starter engine is located in a Citroen C3? I have found its molten fuse and although I have replaced it, it does not work. The battery is ok. Giving some touch to the aforementioned engine would work again or else there is nothing more to change it? Thanks from the anterior
14 years 1 month before #23588 by manual-mecanica
Manual-Mecanica Response on the Re: Motor Start Citroen C3
The starter engine in the C3 is located at the rear of the engine, just below the admission collector whether it is a gasoline engine as if it is a diesel. Although if giving him some blows, he will work again, you will have no choice but to replace it since at the least thoughtful moment he becomes locked again.
14 years 1 month before #23591 by manual-mecanica
Because you don't get it better and you change the brushes (coals) if you hit it again it is very caused that they are spent
14 years 1 month before #23620 by manual-mecanica
It is true here in Chile they are repaired, of course in other countries they only change and already, but it is possible to repair them, all their induced parts, coals, vendix and solenoid are sold.
14 years 1 month before #23650 by manual-mecanica
And well here in Uruguay for costs almost always repair it is rare that a starter be changed
