Ibiza Rota Distribution Correa 1.9 SDI Year 99
14 years 3 months before #23473 by manual-mecanica
Rota Ibiza Distribution Correa 1.9 SDI Year 99 Published by Manual-Mecanica
The distribution strap has been split and I have placed a new one but I don't know how to synchronize the different pine nuts,
so the car does not start, does anyone know how to do it? thank you so much
14 years 3 months before #23524 by manual-mecanica
Manual-Mecanica Response on the Re: Rota Ibiza 1.9 SDI year 99
Hello friend, every four -stroke must with the piston in pms (above) give the trslape in the valves of that piston or closes escape -abre admission .... luck (
14 years 3 months before - 14 years 3 months before #23527 by manual-mecanica
That such a friend ... Here I leave you the manual, the specific engine that comes there, just give it a leaflet and there you find everything. I hope to help ... greetings
Latest edition: 14 years 3 months before by .
14 years 3 months before #23546 by manual-mecanica
You may already have it solved just tell you that once you have the distribution in the manual, as the manual that the partner must take special care when tensioning the belt that the brand you have in the hole in the gearbox does not move does not move once this is unlocked the camshaft, you unlock the injection pump you give on hand two turns to the cran It is fine and you would have problems greeting I hope it helps you.
