PALIO 1.8 2008 ACCELERATION PROBLEM
14 years 4 months before #23339 by manual-mecanica
Problem Acceleration Pallio 1.8 2008 Published by Manual-Mecanica
Dear forists, first of all a cordial greeting.
The problem presented is related to the acceleration body of a Fiat Palio Elx 1.8 year 2008. Specifically in the motorized butterfly valve response, at the time of activating the pedal. That is, there is a time delay between the time to activate the pedal and the engine acceleration response. I am aware that the acceleration system of these vehicles is "positional service", so I presume that the problem could be in the configuration or adjustment of the parameters of this control system. I have tried to find a workshop manual for this vehicle model, but I have not had any luck. If any of you has had a similar problem and can guide me about it, I will know how to thank greatly.
Cordial greetings,
Diego Toledo
Puerto Ordaz, Venezuela
14 years 4 months before #23373 by manual-mecanica
Manual-Mecanica Response on the Re: Problem Acceleration Palio 1.8 2008
Indeed, the big problem of Fire models of Fiat is the motorized butterfly, you can try to disconnect the battery about 30 seconds, then you open contact 20 seconds and close it 15 seconds you repeat this about 3 times and then you start having what happens, if you do not fix the only way to configure it is the commercial house, to another thing you can try another abe
