Motor Turbo
17 years 9 months before #2333 by manual-mecanica
Motor Turbo Published by Manual-Mecanica
I need help I have a CBR 900Rr Honda Motor 1999 and I want to make it turbo if there is someone who can help me, I will appreciate it.
Thanks, Melvo
17 years 9 months before #2348 by manual-mecanica
Manual-Mecanica Answer on the Re: Motor Turbo
You are playing with fire and you are going to burn, supercharging an engine is fine work, because you have to lower the engine compression ratio, modify the feeding system, look for an adequate turbo, modify admission and exhaust collectors to locate the turbo, look for oil and return corner ...
It is a lot of money and if you do not do well you can paste a quite fat exploited.
Anyway, he asks at www.forocepos.com or search the Google or on YouTube \ "Smart Diablo \", because I think I remember that I was carrying the engine of a kawasaki with a turbo or I don't know what, the case is that it runs like a headless chicken.
Greetings and get away when you try it, do not go to be a piece of the engine !!
