LSColn LS V8 cooling system
14 years 5 months before #23288 by manual-mecanica
Lincoln LS V8 cooling system published by Manual-Mecanica
Problems with the lincoln ls v8 cooling system ... with hydraulic fan .... it heats up and the hydraulic fan does not increase its speed according to revolutions .....
14 years 5 months before #23301 by manual-mecanica
Manual-Mecanica response on the Re: Lincoln LS V8 cooling system
The hydraulic fan is the viscous coupling? If so, you have to change it or cross a bolt and leave it fixed.
14 years 4 months before #24225 by manual-mecanica
As I put the bolt!
14 years 4 months before #24227 by manual-mecanica
Here the problem that check does not
act
10 years 4 weeks before #50326 by manual-mecanica
Manual-Mecanica Response on the topic Lincoln LS V8 cooling system
Carnal Help I have a linconl ls v8 the radiator was changed.
