Fiat Panda Active address problem
14 years 4 months before #23284 by manual-mecanica
Fiat Panda Active Directorate Problem Published by Manual-Mecanica
Good evening,
the Fiat Panda direction was blocked 3 days ago, it got like a stone.
I would like to know if someone can tell me what it is.
Thank you so much.
14 years 4 months before #23285 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem Fiat Panda Active
Something with electronics ... I think the address is electric
14 years 4 months before #23299 by manual-mecanica
It is likely that what has been brought to you is the bomb of the assisted direction when the direction is failed.
14 years 4 months before #23303 by manual-mecanica
It depends I do not know if it is electric if it is so then if I could go through a reset, although I doubt it I believe more in a failure in the electrical system and that they did not find the failure.
14 years 4 months before #23305 by manual-mecanica
Bad news friend normally Fiat Falla Failure of addressing that goes in the address column had some types that the connector failed but they were the least
under the steering wheel is the letting fierce and plug and then disconnects the two terminals of the battery and the joints 30 seconds and describe connect the battery again if you can almost almost change the direction column
