ADVICE
14 years 1 month before #23112 by manual-mecanica
Council published by Manual-Mecanica
Hello atodos those of the forum today is the first time that I request a advice I just adjusted an engine of a Jeep Grand Cherokee 4.0 6 cylinders but when starting I work for a while since the battery was downloaded, it passes the current but when disconnecting the cables it is turned off and to my surprise the engine is already loosening the center tapas and the rod tapas but it is still moored the crankshaft that I am bewildered that I am moving the crankshaft. They thank you for your comments beforehand and if you send me any meshas here I leave this email
14 years 1 month before #23144 by manual-mecanica
Manual-Mecanica Response on the topic Re: Council
What do you mean with the engine?
14 years 1 month before #23203 by manual-mecanica
B) Remove the top of the crankshaft one x and verify that the metals are not run (above one another) if you are not doing the same with those of connecting rods, if this were the reason that the engine is tied the engine should be rectified the crankshaft axes of center and connecting rods, put metals on measurement
14 years 1 month before #23262 by manual-mecanica
Thanks in advance for the Council already find the problem it is something strange but true the pistons were inconed to be exact 4 and it is not pulling the rectifier is a factory problem
14 years 1 month before #23263 by manual-mecanica
Friend the pistons swell when there is an overheating, they expand and break or stick to the cylinder, there can also be lack of lubrication.
What I need about that engine will help you
