step -by -step
14 years 4 months before #23075 by manual-mecanica
Speaker step by step posted by manual-mecanica
It will be that this valve is burned and that it will take it and clean it and observe that it has 4 pins to provide them and no continuity or it is normal, I thank you who can help me, I am from Venezuela
14 years 4 months before #23076 by manual-mecanica
Manual-Mecanica Answer on the Re: Step by step
The first would be to know what vehicle we are talking about and if it is a step by step or just an iac ... they are different .. now if you say that no pin has continuity between them .. the motor coils are burned step by step and you should
14 years 4 months before #23106 by manual-mecanica
Hello friend, it is as the partner says, if there is no continuity is burned and you have to change it, greetings. :)
14 years 4 months before #23143 by manual-mecanica
It is true if there is no continuity or resistance means that the interior windings have problems, if so you will have to change it, it is not very normal that they burn for cleaning them is more normal that they burn for trying them directly on the battery.
14 years 4 months before #23167 by manual-mecanica
Friend is a fiat siena engine 1300 year 1999 and if you tine 4 pins between them but it has no continuity friend I have another doubt this sensor helps the engine to develop when one passes the 100 km per hour and goes up I thank you for the answer and help the I am from Venezuela
