Remove Citroen Jumper 2.0 HDI distribution
14 years 4 months before #22878 by manual-mecanica
Remove Citroen Jumper 2.0 HDI distribution published by Manual-Mecanica
Greetings. To change the high pressure pump of diesel I need to remove the distribution strap in a Citroen Jumper 2.0 HDI you need to remove the plastic protector and I cannot take it out because it hits myself in a stainless steel tube that goes above it towards a valve fixed to the balancing cover and then like a distributor or a thicker tube with a couple of outputs. To the valve before that is attached with a kind of clamps that seem to be closed with a special user.
Anyone knows how to remove this tube or remove the tube with the valve? How to remove this dent strap? Or a repair manual of this van.
Thank you
