Oil escape per crankshaft retainer, peug
14 years 4 months before #22774 by manual-mecanica
Oil exhaust per crankshaft retainer, PEUG published by Manual-Mecanica
I have a Peugeot 504 and the oil escapes between the engine and the gearbox
14 years 4 months before #22775 by manual-mecanica
Manual-Mecanica response on the re: oil escape by crankshaft retainer, peug
Hi Pakosigo1953, I am very afraid that you will have to remove the change to change the crankshaft retainer:( , still check that it is not for the balancing cover or by the Carter Board and you are driving you crazy: Whistle: . You will say where the shots go. Salu2 ...;)
14 years 4 months before #22777 by manual-mecanica
Hello friend, although I have not worked with that car model for a long time, I think I keep in mind that it is not held on the rear bench.
It has a helicidal carved in the crankshaft, which returns the oil to the crankcase.
The reason for the loss can be given if you have excessive axial game or a great bearing wear. Or, (which is usually the most common) can lose for rubber stamps that go to the sides of the bench.
I hope it serves you, but consult it with someone else because as I said I have not touched an engine of those.
Juan Meoniz
14 years 4 months before #22779 by manual-mecanica
Try this product slick 50 regenerating together and withholding the same thing I solve your escape I have never tried it but the mark of these additives is the best look in its paguina luck www.slick50.com
14 years 4 months before #22786 by manual-mecanica
Hello, I am. ING. Automotive I recommend that you take the car to the motor washing and cars service this will not take away your leak but if you can see where it tries the oil. The engine is already linked and start it, observe where the oil comes from and I wish you good luck that it is easy to repair.
