Jeep Gran Cherokee 99 4.0L Transmission problem
14 years 6 months before #22724 by manual-mecanica
I have a problem with the transmission Yaque quadado I put it in reverse rarely thunder and in the errors codes I marked p0713 p0753 p0762 p0765 if someone has any response selo would appreciate.
14 years 6 months before #22737 by manual-mecanica
Manual-mechanics ' response on the topic Re: Jeep Grand Cherokee 99 4.0L transmission problem
All the codes point to the valve body. You should first check the wiring harness, and then, when you have no other option but to drop the transmission, check the valve body to see if it's electrically actuated and everything. If it's not, then you'll have to replace it
