starting motor
14 years 4 months before #22693 by manual-mecanica
starter engine published by Manual-Mecanica
Hello someone knows the tests that are done to a branch engine for repair
14 years 4 months before #22697 by manual-mecanica
Manual-Mecanica Response on the Re: Starter Motor
Hi Mirco, you have to prove that the sweet potatoes and the induced are not short, that the bushings do not have a game and the length of the brushes is enough to have a good contact, that the solenoid works well by calling the Bendix and that the Blessed Blessed himself does not skate when entering the crown, I hope you help you, greetings. :)
14 years 4 months before #22700 by manual-mecanica
If you try it outside it in a battery, the body of the start is land, and you feed it with a positive cable from the battery to the solenoid terminal where the battery is ba, then you make a bridge with the remaining terminal, let go and turn if it does not come out it is the induced fault if it does not rotate are the coals that is the basic, then the Bendix is ​​going to be blessed for a single side.
