Transit 09
14 years 2 weeks before #22683 by manual-mecanica
Transit 09 Published by Manual-Mecanica
Change the transit's diesel filter and it does not start a lot of help.
14 years 2 weeks before #22690 by manual-mecanica
Manual-Mecanica Response on the Re: Transit 09
The filter put it with oil or dry?
14 years 2 weeks before #22695 by manual-mecanica
Silo I put without diesel hears a question where you purges the injection pump or where the filter is put to you very much
14 years 2 weeks before #22699 by manual-mecanica
It is best to snap the same injectors you are loose and give it until it comes out oil and nothing else, then if you have Sevador you give the Sevator but of the injectors it will be enough is long if you do not believe that it will be fast passance and nothing more lucky
14 years 2 weeks before #22702 by manual-mecanica
I did what you told me I stayed, thank you very much for the help if I can help you with something I take your hand and thank you again
