My Logan 2008 does not turn on
14 years 4 months before #22619 by manual-mecanica
My Logan 2008 does not turn on Published by Manual-Mecanica
There is pressure on the 110 lbs gasoline pump stack, there is current in the coil, injectors, it has new spark plugs, new gasoline filter, the computer was checked and OK is, the position sensor was changed (plane), we take out the flute and when giving for the swich there is gas injection in the injectors, new temperature valve, the new temperature valve was changed, the fuel pressure regulator was changed gasoline pump, just turn on if fuel feeds on the acceleration body until it is consumed, help please appreciate them
14 years 4 months before #22620 by manual-mecanica
Manual-Mecanica response on the Re: my Logan 2008 does not turn on
I would begin by checking if the key is recognized by the transpondor
14 years 4 months before #22644 by manual-mecanica
If you have an impact button you may be disarmed, check it.
14 years 4 months before #22645 by manual-mecanica
Have you taken the compression ?????
14 years 4 months before #22647 by manual-mecanica
Check the injection pulse
