Ford Focus 2000 loses power
14 years 4 months before #22519 by manual-mecanica
Ford Focus 2000 loses power published by manual-mecanica
Hello friends, I have a Focus 2000 and when it is in use, it suddenly goes out and loses power, it also has about 3 minutes of ignition and is very hot and you could tell me how to graduate the clutch since it is hydraulic and I do not know how it is done for your help thank you very much.
Jasson Black
14 years 4 months before #22537 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Focus 2000 loses power
Hello dear. A good mechanic, always begins from the simplest to the most complex. If you talk that your car loses power and stops, you must have a problem, in your fuel admission and circuit, I mean that it must be dirty, so you should start by making a tune, including injectors lipiege. If you have done it, and the problem persists, I recommend scaar your vehicle, to rule out possibility, that some sensor is producing an anomaly in the operation of your engine.
Regarding the clutch question, I do not understand what you mean by graduating the clutch. Your clutch is not hydrauyl, yes, not hydraulic drive, so if it is failing etc, specifies more on the subject.
14 years 4 months before #22569 by manual-mecanica
Hydraulic clutches do not have regulation, sometimes can be extended or shortened a little from the pedal but it is not clutch's graduation, and with respect to the power of the czech, what is already mentioned because the clutch has nothing to do with if your vehicle stops, if it takes a long time to start you can have a problem with the temperature sensor.
