Corsa ignition
14 years 6 months before #22508 by manual-mecanica
Corsa Ignition Published by manual-mecanica
I have a 4 ptas corsa. Year 96 synchronous. The problem you have is that when I turn on it sounds to me something at the start that turns but does not finish starting. I have to push it.
14 years 6 months before #22512 by manual-mecanica
Manual-mechanics' response on the topic Re: Corsa ignition
But does the combustion engine turn? If it doesn't, it's the Bendix, a component that functions as a clutch inside the starter motor.
14 years 6 months before #22514 by manual-mecanica
Hi friend, as the other person said, it's most likely that the starter bendix is ​​slipping. You'll have to remove it to replace it. Let us know how it goes. Regards. :)
14 years 6 months before #22520 by manual-mecanica
Everything's fine here; this is my first time registering on a forum. I think it's very helpful. Regarding my problem, I'll try starting it directly from the front, then I'll rule out whether it's the ignition switch, the switch itself, or a cable because I'm already worried. Thanks for the replies; I'll post an update when I fix it
14 years 6 months before #22566 by manual-mecanica
It is only the vendix if it turns and it is not heard that it comes out and hits then this does not succeed.
