Peugeot Partner brake problems
14 years 5 months before #22392 by manual-mecanica
Manual-Mecanica Answer on the Re: Peugeot Partner brake problems
Hello partner, as they have already cited, the problem can be originating the depressor (empty pump) but it would be good to verify s there are no leaks or if any valve that works with this system is open,
14 years 5 months before #22397 by manual-mecanica
Everything is apparently verified if it is the empty pump, the first braking is regular and the second one is lasted the pedal thanks for the contribution to all.
14 years 5 months before #22401 by manual-mecanica
Get a mechanic that has an empty tester and tell you if the pump is good or should not mark 25 to 30 in minime
14 years 5 months before #22403 by manual-mecanica
I have an empty tester to what extent my data is my tester in inches (in)
