Renault Express clutch
14 years 2 months before #22342 by manual-mecanica
Renault Express clutch published by Manual-Mecanica
Good to everyone
I have a Renault Express and in December I change the clutch (full kit) but when I am going to do so it does not arrive or very fair I look at the pedal, nothing good changed the new clutch cable nothing at the end I had to put a filling between the cable and the box but it is hard the leg is demoralized. And in the end I get to the conclusion that if they have given me a plate of another model that has given me a plate that has given me a plate that has given me a dish.
I don't know if someone has happened to him or can illuminate me with something else.
thank you
14 years 2 months before #22353 by manual-mecanica
Manual-Mecanica Response on the Re: Renault Express clutch
Friend on occasion when riding clutches it happens that the press is too flat and the pedal shorts very down, if you have a regulation of piola or pedal because giving regulation, as the album is spent the press comes out a bit and the pedal is normalized, on occasions you can put separators between the press and the steering wheel but if you do the clutch it will last less time. luck
14 years 2 months before #22394 by manual-mecanica
Good
I don't know what you mean by what is a flat press that comes badly? And regulation on the pedal is butt and I have a filling between the end of the cable and the gearbox.
if not, should I take it away?
14 years 2 months before #22398 by manual-mecanica
Disassemble the box and check, the press is the diaphragm, I don't know what it will be called in your country, but when the marches are not very flat, the marches are not very flat,
14 years 2 months before #22448 by manual-mecanica
disassembling the box? That is just what Joer does not want to do with the work he carries.
I know it as a pressure plate if we are talking about the same and what you tell me is that it came very flat or that when there was something wrong, which I do not believe if not it would not official.
thank you
