Golf TDI 140 hp stops
14 years 5 months before #22324 by manual-mecanica
Golf TDI 140 CV Standing by Manual-Mecanica
I need help, I have a 2006 Golf TDI 140 hp and when I do 400 or 500 km it starts to lose power until I stop.
14 years 5 months before #22326 by manual-mecanica
Manual-Mecanica Answer on the Re: Golf TDI 140 hp
The problem you have is also not explained everything, as is the temperature of the water
, such as the oil pressure, the vehicle makes some strange noise of the normal, as
reviewed in the electronic system if the system has a temperature error if indicated on the
greeted
14 years 5 months before #22333 by manual-mecanica
It is true a little data, you checked the state of the spark plugs if they are very black, some symptom is always when rolling or with a stopped vehicle also does.
