Ford ka 1.6 lts
14 years 4 months before #22318 by manual-mecanica
Ford Ka 1.6 Lts Motor Published by Manual-Mecanica
Good morning, there is no current in the Motor of the Ford Ka, it does not start or turn on pushed, they light all the indicator lights when the key will pass, when doing the ignition nothing happens, it came rolling and turned off alone, the battery is new, thank you greetings greetings : UNSURE:
14 years 4 months before #22319 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford K Motor 1.6 Lts
I recommend reviewing all the fuses first, before disarming some element.
14 years 4 months before #22320 by manual-mecanica
The red light of the clock button is not on? for discarding the immobilizer ....
14 years 4 months before #22323 by manual-mecanica
Good afternoon friend you check the switch is located below the steering wheel and check it must have a burned or sulphotic connector but it is better to change it than to clean it if you do not have a bridge with a cables and you will see that I turn on I hope my help serves you
14 years 4 months before #22332 by manual-mecanica
Friend also remembers that the Ford Ka on the left side look at the front and under the hood has an harness connector that is round and with many Czech cables that is not loose or disconnected and re -connect it to me, I am angry that luck connector.
