Corsa 2 computer
14 years 5 months before #22143 by manual-mecanica
Corsa 2 computer published by Manual-Mecanica
It is possible that my Corsa 2 computer has partially decompose?
14 years 5 months before #22144 by manual-mecanica
Manual-Mecanica Answer on the Re: Corsa 2 computer 2
I think it is necessary that more information about what is the problem of your car to help you.
But if you just want to know if your computer can have partial damage the answer is yes !!
14 years 5 months before #22147 by manual-mecanica
Hello
, more information is needed, the result of scanner, which generates codes, a prior review of cable harnesses, possible condensation of computer moisture and connector that are factors that could alter their operation as well as loose masses or sudden variations of feeding voltage
greetings
14 years 5 months before #22177 by manual-mecanica
Leunamcocker wrote: is it possible that my Corsa 2 computer has partially decompose?
Yes, it may be, but you should indicate because you believe that!
Greetings
14 years 5 months before #22180 by manual-mecanica
Because gasoline does not work and the mechanic told me that a part of the computer does not work that is the injector output. Greetings and thanks.
