Automatic Swift 1.6 Motor Start
14 years 5 months before #22208 by manual-mecanica
Manual-Mecanica response on the Re: Swift 1.6 automatic motor start
Good afternoon thanks for the help, I did what I suggested fried, but the engine did not react. Additional I suspended the fuse of the gas pump to interrupt the step, and that burn the waste of the spark plugs and the motor combustion chamber, but the spark plugs did not burn the gasoline that soaks them despite having a spark on the spark plugs.
I also put some hotter spark plugs but it was useless, I just need, check the compression of the engine, to see if it is an internal engine damage or is poorly repaired.
14 years 5 months before #22209 by manual-mecanica
Before he failed, gray smoke began to turn it on and when he heated the engine, the carburetor was normalized and cleaned.
But then the ignition became hard and the engine lost strength.
Thanks for the help.
