crankshaft position sensor
14 years 5 months before - 14 years 5 months before #22094 by manual-mecanica
crankshaft position sensor published by Manual-Mecanica
I need you to help me how to measure the crankshaft position sensor of a Ford Fiesta TDCI 2003. I hope your answers. greetings
Latest edition: 14 years 5 months before by .
14 years 5 months before #22095 by manual-mecanica
Manual-Mecanica response on the re: crankshaft position sensor
Hi Nicols visit this website easyautodiagnostics.com ckp and CMP Sensor Basic Diagnostic Concepts I hope it serves by Chaoo
14 years 5 months before #22096 by manual-mecanica
Thanks for your contribution, but it's not what I'm looking for the same is very missing, greetings
14 years 5 months before #22099 by manual-mecanica
I don't know what type of sensor your car brings but if it is two cables, measure the resistance with a multimeter tedeberry to give around 600 to 1100 ohms if you give you these readings, change the multimeter to measure volts on the 2 volt scale in alternating current must measure .2 to 1.8volts if it is 3 o4 cables identifies the current cable and the ground and the other tips Vary when the boot rotates for desiring an amount of 0 to 5 volts I hope it helps you something friend Nicols
14 years 5 months before #22113 by manual-mecanica
If it is reading, one is one direct land, the other is current and the other variable or signal, between two of these pins you have to have a resistance of 600 to 1000 homs this will depend on the temperature at which the test is realized, when the free pin is connected and when moving the steering
