Problem with a Blazer 97
14 years 5 months before #22087 by manual-mecanica
Problem with a Blazer 97 posted by Manual-Mecanica
Friends:
I have a big problem with a Blazer 97 ... starts very forced, as in 2nd and the last change goes to more than 3000 revolutions when I should go to 2500. I have sent him to lower the box 2 times, but I have not had a tailoring result.
If someone can help me, I would be very grateful
greetings
Djzamba
14 years 5 months before #22088 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with a Blazer 97
There you have an oil leak in the valve body or the turbine is bad and check the governor
14 years 5 months before #22109 by manual-mecanica
Look Czech the governor and the valve box
14 years 5 months before #22118 by manual-mecanica
The governor, is it a piece inside the box?
Greetings
14 years 5 months before #22122 by manual-mecanica
Yes and the valve body is located below when you take the poster you will see it
