how to consult International Failure Codes
14 years 6 months before #22025 by manual-mecanica
How to consult International Falla Codes published by Manual-Mecanica
How do I ask for fault codes in International Truck2003, DT 466-Ey Motor List of Codes Thank you
14 years 6 months before #22044 by manual-mecanica
Manual-Mecanica Answer on the Re: how to consult International Failure Codes
On the instrument board, next to the helm column you must have a diagnostic switch. Activating it gives you the light flickering codes. I will upload the codes table in a PDF file. I hope you help you.
14 years 6 months before #22045 by manual-mecanica
This is the table.
14 years 6 months before #22101 by manual-mecanica
: Cheer:
Thank you very much Jorged, helped me a lot, since I guided me to detect the fault that the truck had and protected, and lowered the power, greetings : Laugh:
10 years 8 months before #48875 by manual-mecanica
That such a good day I have a question about an International CF600 Model 2005 VT275, you could recover fault codes by means of the check engine witness board for flicker ... thanks and if I can do how I would do
