Problems with Clio Authentique
17 years 10 months before #2201 by manual-mecanica
Problems with Clio Authentique published by Manual-Mecanica
Hello friends, someone from you. I could tell me that it fails can have my Clio Authentique 2003 .... The weekend began to tremble the car ... it tells me a round alarm that seems like a water pump I read in the user manual that comes in the car and I think it is from the escape emissions ... ah that they believe it is due because the engine begins to tremble and slow speed trembles a lot and flashes the alarm
... For their services ... with the fact that they get an eye out of the face ... I am thinking that you have to need a tuning and already ... but someone from you. I can guide me, I will thank you ...
you also get alarm drawing that carries the doll with the seat belt ... and the service. They believe it is a false contact ...
17 years 9 months before #2258 by manual-mecanica
Manual-Mecanica Response on the Re: Problems with Clio Authentique
Hello, if it is Diesel, that this model I do not know, it is likely that it is the EGR valve, which is grabbed, I pass to my clio, if it is this, good news and bad news, the good is that you can clean it or cancel it, very carefully since if it cancels bad it will be worse, and the bad is that until you erase the failure of the memory will continue to indicate it to you. Usually people do not have a strip at home, you need a workshop, it is not necessary official but trustworthy, and who possess the happy computer.
The belt, a contact is most likely, looks under the seat with care, and continuity tests between contacts if it fails, as simple as cutting and welding, not doing strange things, taging is very simple and we take away from fatter problems.
I don't know if it will serve you but less is nothing. greetings
17 years 9 months before #2385 by manual-mecanica
Thanks to Aitor1987, apologize for the delay in response to your help ... The truth is that they already fixed me in the car the problem was with an ignition coil, taking advantage of this change I make my tuning because I already asked for it to shout ... Only the notice of gases and emissions continue on but the next day was deleted alone, I think I take the computer as good and eliminate it ... Rare Truth !!
From the belt and check the cables and I think I know if it was a false contact because my board with the alarm no longer illuminates.
Thank you very much Aitor.
17 years 9 months before #2390 by manual-mecanica
At all, at least I have helped you in one of them, and I am glad, since my experience is short, and I have only written why I have a clio, and I have been a couple of months in Renault, and it used to be what happened. For your good I hope I have not to make a cable again (do not have more damages). greetings
