Corte cut Kangoo 1.6 16
17 years 10 months before #2196 by manual-mecanica
Corta de Correa Dist Kangoo 1.6 16 Published by Manual-Mecanica
Hello, could you tell me if the 1.6 16v dolla valves? And I want to know how the belt is cadabia, thanks
17 years 9 months before #2268 by manual-mecanica
Manual-Mecanica Response on the Re: strap cut Kangoo 1.6 16
Yes bend valves if the strap is released, to change the distribution strap if you do not have much idea do not teach your luck and take the car to a workshop.
If the belt is wrong or the engine is bad synchronized, it can cause engine destruction as soon as they give the starter key.
All the best.
17 years 8 months before #2550 by manual-mecanica
Friend if your Kangoo goes wrong, put your complaint on the portal of the Profeco. There are already more than 100 complaints for failures of Renaul cars.
www.apestan.com
portal .
17 years 8 months before #2607 by manual-mecanica
All 16v engines have the \ "problem \" that if the belt is broken, pistons brand valves and in most cases bend cranks in a few words it comes out cheaper to put another engine, or lightened or scarter than repair the one that has been broken. To change the distribution you need adequate tools, I do not know if you have them (a 1/2 and 1/4 inch carrack As much as I explain here in practice it is more complicated but if you dare I can make some drawings so you can see it when they tell me how it is done to hang them on the page My email is
