Very hard standard transmission
14 years 5 months before #21949 by manual-mecanica
Very hard standard transmission posted by manual-mecanica
Hello, I just bought a Pontiac Sunfire
and I find that the transmission is too hard already know the previous owner, he told me that since it is heated that when it is cold, etc.
But I tell you what the car does
if it is aligned to the left the first and the second one enter without problem but to change to third you have to travel towards the center the lever and this movement is the one that is difficult to do once it is easy it is easy to change from fourth to third
and the same goes for to pass to the fifth
that is to say they see the drawing of the lever 3 above and three below
because it is like it is looked peers is easy to put the changes
14 years 5 months before #21964 by manual-mecanica
Manual-Mecanica response on the Re: very hard standard transmission
For me you have a problem with the selector lever either lack of lubrication or wear of Checala components disassembles from the inside.
14 years 5 months before #21983 by manual-mecanica
You must check the synchronizers of the box may be spent and have to replace
