MY VOGER93 brakes do not work properly
14 years 5 months before #21928 by manual-mecanica
MY VOGER93 brakes do not work properly published by Manual-Mecanica
Hopefully they could help me what is scarce, my voyager 1993 are hard as if the truck was off I do not know if they understand me. If it slows well, but they are hard and sometimes heard as if he vibrated or surrounded something in the brakes and if they could tell me where the relay is. Thank you I hope you help me.
14 years 5 months before #21984 by manual-mecanica
Unbes check but the boster hose to the engine is deconed or check the ABS pump
14 years 5 months before #22029 by manual-mecanica
That symptom is typical of when the servo is not working, or some covered emptiness hose, check them first before spending a large sum in their repair.
14 years 5 months before #22051 by manual-mecanica
The problem you have is typical of a Booster damaged by symptoms 1 Check the empty hoses that are not hindered bending 2 Check your chec balbula just unve But if not the booster is damaged
14 years 5 months before #22085 by manual-mecanica
Greetings Friend ... If the brake pedal is very rigid but it slows it is because it is sending the fluid correctly to the limestones or brake drums and that is because the hydrovac, brake booster, reinforcer, force multiplier or as you want to call it already fulfilled its life time, this is the round piece that is jointly found with the fluid pump ... you only buy a new one, you brakes and voila ... Good luck !!!
