Doubt with a topaz 92
17 years 10 months before #2185 by manual-mecanica
Doubt with a Topaz 92 posted by Manual-Mecanica
Hello, how are they I want to know if I could help myself, I have a topaz 92 and I am fighting with the old man on the driver's side ago a noise was heard as if the tire had an embedded stone and when I accelerated the noise it was faster and when I reviewed it it tells me that it was the old man who had a lot Occaaciona that could be something else because I rare that in Tanpoco time I would have that fault if someone can help me I will thank you very much greetings to everyone and thank you : SIDE: : Dry:
17 years 10 months before #2187 by manual-mecanica
Manual-Mecanica Answer on the Re: Doubt with a Topaz 92
If you have the unbalanced wheel, the badly aligned direction, the deformed tire or the shock absorber on that broken side, (sometimes it is not known that it is broken because the oil does not come out) what you cause are vibrations in the direction that end up breaking the bruises and silentblocks of the trapeze on that side.
It is best to check the entire rolling assembly (the two best sides) and make a direction aligned, a balanced wheel and visually check clearance and the state of the tires of the silentblocks of the trapezios and the stabilizer bar if it took it since if they wear out, eat wheels, it derives in the curves and loads the ballows.
PS If everything seems correct, do not discard the bad assembly or the factory defect of the replacement, which sometimes passes. (although it is not very frequent)
a greeting.
