MERDECES SPRINTER 413 CDI
14 years 7 months before #21803 by manual-mecanica
MERDECES SPRINTER 413 CDI Published by Manual-Mecanica
I have a problem with a sprinter 413 CDI .. when it is running around 2000 rpm, a pounding is heard in the engine ... what can I do to find the fault ...
14 years 7 months before #21815 by manual-mecanica
Manual-Mecanica Response on the Re: Merdeces Sprinter 413 CDI
Good Walteradri, if the car humans, check the injectors, which are the majority of sound causes as a hammering. LUCK AND SALU2 B)
10 years 9 months before #48744 by manual-mecanica
Manual-Mecanica response on the topic Merdeces Sprinter 413 CDI
Dear, take out the filter element and look at its cells, if you have metallic waste it is because of metal wear, start for that. How many kilometers do you have ??
