Nissa QG15
14 years 7 months before #21790 by manual-mecanica
Nissa QG15 published by Manual-Mecanica
Hello friends, I have a problem with a Nissssan QG15 has a PO335 fault cod Unit has a canbiad Ecu
14 years 7 months before #21833 by manual-mecanica
Manual-Mecanica Response on the Re: Nissa QG15
Suddenly this fault or after a repair?
14 years 7 months before #21861 by manual-mecanica
Hello friend thanks for responding. The damage apparently was because it burned the coils and renled the ECU. When they re -call the ECU all normal and after several days the witness of the fault of the cable Tecuis
14 years 7 months before #21865 by manual-mecanica
Check the time chain if I am not mistaken this carra has two sensing one of crankshaft and the other of the camshaft if it is synchronisted the time will turn on the light light to verify that all points are in a position CORRECT.
14 years 7 months before #21878 by manual-mecanica
Hello, it is surprising what you say it changed the Ramal Ecu and Sensor even even the pulley but I ask you a question you have noticed the signs of the camshaft if you want a query we can help us my number is also I am also electromechanical I am from Peru my cel 96260027
