Spark plug problem
14 years 5 months before #21747 by manual-mecanica
Spark plugs published by Manual-Mecanica
I have a Samurai Model 95, it is presenting a problem in 1 of the 4 spark plugs, it is soaked with oil. And the car begins to fail.
What should I do ???
14 years 5 months before #21750 by manual-mecanica
Manual-Mecanica response on the re: problem in spark plugs
Paul the oil enters or by butts or by rings, if they are the vast valve seals with taking out the cylinder head to make the change, and there you take advantage of checking the state of the rings. luck .
14 years 5 months before #21811 by manual-mecanica
Thank you very much for the solutions they gave me.
14 years 5 months before #21819 by manual-mecanica
Well, if you enter through the valve capuchones there is no other than replace them if you enter through the cylinders, you will have to ring the engine and if you want a fast solution, buy some increases in spark plug but if it is a lot of here it will not serve anything
14 years 5 months before #21831 by manual-mecanica
I would advise you that as a first measure you take engine compression if the compression is couple it is not necessary
