temperature rise Renault Laguna IV
14 years 5 months before - 14 years 5 months before #21701 by manual-mecanica
Renault Laguna IV temperature rise published by Manual-Mecanica
The temperature raised and does not go to more than 30 km/h, purge the refrymentation circuit and remain the same. The voice of the computer says: On engine heating, turn off the veículo
the electro fan does not stop and consume the battery
from where the problem is, thank you !!!
Latest edition: 14 years 5 months before by .
14 years 5 months before #21704 by manual-mecanica
Manual-Mecanica Response on the Reault Laguna IV temperature rise
Hello friend, you controlled that the thermostat works well and has not been locked? Tell us as you are going, greetings.:)
14 years 5 months before #21707 by manual-mecanica
First, what is cheese that is the cylinder head and packing of it are not passing oil to the water, water to the oil or compression to the refrigeration system, nor is it putting the water to the combustion camera.
14 years 5 months before #21730 by manual-mecanica
hello.
I believe that cylinder head packaging. And you have a compression loss towards the cooling circuit.
luck...
14 years 5 months before #21743 by manual-mecanica
If I would first bet on the cylinder head ... Check the compression and if it puts water with oil. smoke by escape ??
