Ford Mondeo Gasolina trembles
17 years 10 months before #2170 by manual-mecanica
Ford Mondeo Gasolina trembles published by Manual-Mecanica
Hello I have a Ford Mondeo of 1.8 16V 110CV of 2001. This car produced a problem in the ignition, specifically the spark plugs were destroyed by the electrode and it was the problem of the light As if the car trembled at the idle. The truth is that I don't know where to get hand, a little help thanks.
17 years 10 months before #2186 by manual-mecanica
Manual-Mecanica response on the Re: Ford Mondeo Gasolina trembles
In case I had the failure with the ignition again, check the separation of electrodes from the spark plugs and the high cables, it will not be that you have mass leaks in the form of spark.
If everything is fine, you can have a crankshaft position sensor in poor condition, so it goes back, (but in that case the breakdown light would immediately turn on).
Another reason why I headed the engine in idle is because of the issue of injection, but if the fault light would also ignite (Lambda probe failure, flowmeter failure or failure in the gas butterfly contact box).
Sometimes there are failures in injection motivated by improper air intakes in the engine, check all clamps and sleeves from the intake manifold to the air filter, and check the connectors does not fence that one is oxidized or loose.
All the best.
