Low lubrication in 5.3 vortec engine of silverado
13 years 9 months before #30424 by manual-mecanica
Manual-Mecanica response on the Re: Low Lubrication in Silverado Vortec Motor
Hello fried I have an avalanche 2007 and I have the problem I mark me low oil pressure, Stabilitrak, I do not know how to fix it I already have the new sensor in which part of the engine carries the sensor?
13 years 9 months before #30434 by manual-mecanica
Hello cars, your problem is not in the sensor, your problem is the urine of the oil collector that is already bad and you have to lower the carter and take out the collector you change the orin and but before mounting that orin you place one more thin one of the same size and then you mount the original orin of the same thickness and you move everything and you have solved your problem. I hope my help serves you
13 years 9 months before #30461 by manual-mecanica
The engine sounds a lot a cold pointer but when it is heated a little stop sounding but sometimes when it has a long time working it sounds like this it is because of the same problem of oil pressure or that could be
thanks for the previous council
13 years 9 months before #30468 by manual-mecanica
If this is therefore these engines carry tacks on rolines and work on the lift tree
13 years 7 months before #33144 by manual-mecanica
Hello, how do you see if you could help me solve the oil pressure problem of a 06 Silverado with Vortec 5.3 engine. I already change oil pump and the tac tac of the diver is not removed, what I want to do is change the diver but I don't know how to do it, if someone has knowledge about this I would appreciate it to help me solve the problem
