PALIER FORD Fiesta 1990
17 years 10 months before #2154 by manual-mecanica
PALIER FORD Fiesta 1990 Published by Manual-Mecanica
Hello everyone, my problem is that I do not know how to get the Palier from the Ford Fiesta year 1990 1.1 cc of gasoline, I hope you can help me.
17 years 10 months before #2161 by manual-mecanica
Manual-Mecanica Response on the Re: Palier Ford Fiesta 1990
Once you have everything loose on the other side (hose, suspension, direction, etc ...) the stick is involved in the differential of the gearbox by pressure.
The Palier, on the tip has a striatum and that striatum has an elastic ring that retains it, what you have to do is make lever with care to separate the transmission out. Either with a detachable or large flat or heavy screwdriver. You have to empty the valvulina of the gearbox first because you run the risk of being poured on top when you take out the transmission of the box.
All the best.
