!!!AID!!!! I need Seat Ibiza Manual TDI 2002
14 years 6 months before #21339 by manual-mecanica
!!!AID!!!! I NEED MANUAL SEAT IBIZA TDI 2002 Published by Manual-Mecanica
Hello ....
Well, I need a workshop manual for Seat Ibiza TDI 2002 onwards, since I have a failure in the "4F9" air conditioner and the fan does not exe air.
I have it disassembled and the fan in my hand ... but ... how is it broken?
Where is the fan resistance located?
Many doubts in the end.
They ask me in a workshop 560euros .... a pass.
Thank you very much in advance.
14 years 6 months before #21360 by manual-mecanica
Manual-Mecanica Response on the Re: !!! I need Seat Ibiza Manual TDI 2002
Good, I am with the same problem as you. I appear the 4F9.00 failure, search the Internet and put me that it was the blower. Remove the glove compartment and before disassembling the blower, check the current and did not reach it. (Luckily does not remove the blower because it costs a little work), check that it works because it puts a current with a battery starter .
I followed the cable until, I think it is, a resistance. And an amibo I check the contestor, that several cables arrive, according to doughs (which I think are the speeds) if it came current but the positive and negative no, and I am sure to surely have to be evil for all this to all this, I had already proven the fuses).
So I take the opportunity to see if someone tells me where the blower or fan of the A/A in the Ibiza is going.
14 years 6 months before #21361 by manual-mecanica
I have forgotten.
The electrical scheme of the weather, is in the manual section, just discharged.
Now I have to catch some colleague who throws a hand.
14 years 6 months before #21384 by manual-mecanica
The fan takes it out and is not burned, if not gripped of the reason and the wear of the caps. I clean it well and exe 3 in the They asked for doing so.
Sorry I don't know where the reverse is .... I will look through the websites to see if I see anything.
greetings.
