Hyundai ACCEN CRDI 1.5 stops only when accelerating
14 years 7 months before #21328 by manual-mecanica
I have this problem that I can't solve: when the engine reaches normal operating temperature and I'm driving, it stalls on its own. This happens when I press the accelerator while shifting gears. It doesn't stall at idle; it can run for hours without stopping, and it doesn't stall even when maintaining a constant speed. After it stops, the check engine light comes on and it shows a fault in the intake air solenoid.
I would appreciate any help with this problem.
Thank you , TEIBOL1.
14 years 7 months before #21403 by manual-mecanica
Manual-Mecanica Answer on the subject Re: Hyundai ACCEN CRDI 1.5 stops only when accelerating
Please help me
14 years 7 months before #21407 by manual-mecanica
Start verifying first the fuel pressure before all you may not have the appropriate fuel pressure (since it can also be the cause)
13 years 11 months before #30393 by manual-mecanica
Hello friend, I have the same problem, but also, the car does not start, we have to push it ... we made a scanner and threw low fuel pressure ...
I took the pond, I checked the electrical pump, this good ... I changed fuel pipes, I loaded the pond full ... I pightened to take out the air ... and continue with the same symptoms .... I no longer know what else to do ... now to check injectors ...
You managed to fix it ???? ....
13 years 11 months before #30399 by manual-mecanica
Friend to check the fuel pressure, it is not necessary to remove the pump from the tank, it is enough to file a pressure gauge between the duct that comes from the tank and the injector rail, only there you can measure the real pressure of the fuel feed system, because it may Injectors. Turn the return duct.
Good luck !!
