Help with an avalanche low lubrication?
14 years 6 months before #21213 by manual-mecanica
Help with an avalanche low lubrication? Posted by manual-mecanica
Good friends had to replace the Orin to the oil pump with low lubrication of a Vortec 5.3 engine of an avalanche my asks is that if you can help me with a wake -up manual of this vehicle or so that please give me the steps to lower the carter since des 4x4 and I have never worked in these vehicles since some medications that I have to lower the transfer and I do not know how to go down. of exploding of this vehicle thank you very much for your collaboration ....
14 years 6 months before #21216 by manual-mecanica
Manual-Mecanica response on the Re: Help with an avalanche low lubrication?
Good evening friend download the transfer no, you have to lift the XQ engine when you take the carter will hit you from the front transmission not from the transfer and that pump does not wear oring she has two pine nuts and already that pinions are worn you have to replace the pump I already have experience I advise you change the oil pump so that you do not lose the work or your engine lifts the engine with a crane or lady as they say here in Venezuela. that remove the nuts from the engine bases and the fan protector
14 years 6 months before #21230 by manual-mecanica
Thank you very much friend for the answer with respect to lifting the engine, it is very reasonable to work with respect to the pump this pump is the one used by the Vortec 5.3l and is placed in the crankshaft. since this with the service time deforms and sucks the Technical Bulletin Number 02-06-01-038 since the taquets enhancing to sound to have the working temperature of the engine ..
