Citroen ZX 1.9 Diesel Turbo Problem
14 years 6 months before #21204 by manual-mecanica
Problem with Citroen ZX 1.9 Turbo Diesel published by Manual-Mecanica
The car turns on normal has normal exit but when I put the fourth march the gear lever begins to tremble, I have reviewed the supports in general and they are fine, and changed terminal labels, alignment and balancing but you perceived the fault if someone can help me please.
14 years 6 months before #21311 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with Citroen ZX 1.9 Diesel Turbo
Hello, if you do it only in the fourth, it has to be the exchange box, differential, you have looked at all the supports etc.
14 years 6 months before #21317 by manual-mecanica
Hello, you will see how Osomarius offers you, you have to check the orchone that mounts in the selectors, wears the balls and docks you can try previously to harden them before disassembling. It is number 5 and 6 of the figure below completely
