CENTRALIZED CLOSE CORSA 2003
14 years 6 months before #21028 by manual-mecanica
CENTRALIZED CLOSCRALIZA 2003 Published by Manual-Mecanica
Hello, my corsa presents the following failure:
When the doors are closed with the key the system does the system but the right back door does not close and I have to close it manually, the strange thing is that sometimes it works and other times not, I have checked fuses I have reviewed the driver's door thinking that there is the fault, but it remains the same, I am still the same, I need to disassemble the door that does not work but I have not done it since I do not think the problem is not there Where is the famous module, if anyone knows the fault would be grateful.
14 years 6 months before #21033 by manual-mecanica
Manual-Mecanica Response on the Re: CENTRALIZED CORSA CORSA 2003
Disable the rear door and look at the wire that affirms the vcentralized closure that is squeezed with a screw, that normally releases or the wire breaks and you have to re -approve it, but according
14 years 6 months before #21076 by manual-mecanica
It is correct only to regulate that pernito and already, it usually happens above all in the corsa
